missing palette icons
Hi
I am having some problems with Labview 2012 SP1, there are missing palettes icons like in Circuit design and simulaion palette I have many missing icons, and if I go into the edit palette option I can see them with a question mark (see missing icons paletts.png), I have re-installed many times the Labview, even Locally and still have this issue. I am using windows 7 64 bits, Labview and all the modules are 32 bits.
I have already set the default location thing and the synchronize with directory, but I am not sure if the files are MISSING (see attachment files.png) and usually it goes like this in the rest of the palettes. I am really not sure how can this be solved, have tried many of the methos here in the forum but no results.
I have a Professional Development System License, tho I am not sure if the system design and simulation should appear in the Modules or the  Toolkits section on the License Manager application were you activate/deactivate
(4,458 Views)
The professional version does not include the control and simulation toolkit. Did you purchase it separately?
(4,439 Views)
Hello lagunasol,
Could you please make sure that you have it activated correctly? Please open the NI License Manager (Start --> All Programs --> National Instruments).
Once opened go: Local Licenses --> LabVIEW 2012 --> Modules.
If you have it activated you should see the “Control Design and Simulation Module 2012” in green otherwise right click on it and activate it.
Please let me know if you still have any trouble.
Regards!
Luis CT
(4,403 Views)
Hiii Luis_CT
I have tried the same what u have said and couldn't get it done. Can u please help me out...
(4,088 Views)
Hi Sai,
to discuss any licensing issues you should call your local NI support!
(4,082 Views)
Hi, can you open a new thread, this forum is old.
Type your problem description and you have done.
(4,054 Views)
