missing sub vi's
Hi. I am looking for the following sub vi's. I am using a 16 channel DAQ board to read analog voltages into Labview. The main VI I'm using was downloaded from NI's examples back in 2004. The PC I used in '04 was thrown out at some point. I am now using the same main VI on a different PC, and I'm missing the following sub VI's. I'm using Microsoft XP and a PCI-MIO-16XE-10 PC card. Where can I find the following VI's?
1. String Column Header.VI
2. Create Data String.VI
3. Multiple Time Delay Match.VI
4. Channel String to Name Array.VI
Thank You,
Braider
(3,919 Views)
They are in examples\daq\solutions\datalog.llb and examples\daq\solutions\transduc.llb on my pc.
(3,914 Views)
Accepted by topic author braider
In addition to Dennis you have to install Traditional DAQ to get the examples. I'm not sure if this is selected by default during installation.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,886 Views)
Thank you both. Is that available on the website or somewhere in my pile of cd's??
(3,876 Views)
It is on the Device Driver CDs/DVD. Start Setup again and look in the product selection dialog. You have to open some of the nodes under Measurement or Data acquisition (don't konw the exact naming).
Waldemar
(3,871 Views)
If you can't find your cd for Tdaq, we have it on our website at our Drivers and Updates page
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,850 Views)
