missing subVi after build in llb
I have a top level application that dinamycally calls some Vi contained in a llb library.
Running the app from source works fine. If I build an application the dinamycally loaded VIs open with the broken arrow. If I click the arrow I see that some subvi are missing:
Block Diagtram Errors:
 Poly VI 'Read From Spreadsheet File.vi': subVi is missing
 SubVI 'Merge Errors.vi': subVI is missing
I build the application including the llb as 'Always included' under source files.
What should I do to have all the llb subVI included or correctly linked ?
thank you
Gianpiero
LV 8.5 + DSC
(2,675 Views)
Try converting the LLB to a directory and build again after testing it with source code.
André (CLA, CLED)
(2,660 Views)
Ciao Gianpiero,
you can take a look at this document:
Creating a Source Distribution, Application Distribution, or LLB in LabVIEW 8.0
Hope this can help.
Andrea N.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(2,641 Views)
