mixed signal graph on wrong tab
I removed the default values from the graphs. The size of the VI dropped to 1.3MB.
Scientia est potentia!
Message 11 of 14
(1,339 Views)
Accepted by topic author magyar
Yeah, you have to manually clear each graph as far as I know. Setting default values to what you really want saves a lot of time in the future because you can reinitialize all to default in one motion, but that obviously doesn't help much if you set your default values to something you don't want.
I'm still not seeing the issue you are when I open your VI. I would suggest dragging the offending "rawsignals" cluster out of the tab control, dorpping it, and then putting it back in to see if that forces it to load properly. If you move that control around, do the ghost graphs move with it?
Cheers
Message 12 of 14
(1,335 Views)
James,
The problem is solved! (or at least disappeared)
I had a windows update that forced itsef through.
After that and after clearing the default values in the graphs I recompiled my code.
it seems to run fine now! So I saved the whole project really fast. 🙂
Thank you for your time and effort.
Message 13 of 14
(1,330 Views)
Heh, alright good!
It might have been the default values causing the interface to get a little angry.
Cheers
Message 14 of 14
(1,319 Views)
