mixed signal graph: scaling of x-axis
Hi all,
I am writing a simple program in LabVIEW using DAQ assistant reading 4 signals from 4 AI channels. I have samples to read at 125 and freq at 250.
I am trying to display this data on mixed signal graph. However, the x-axis cannot be scaled! I scale it to say show 5 s of data, but I still get ~ 0.5 s of plots. They don't stretch out to 5 s. If I change samples to read to 1000, then the graph stretches out to 2 s but then the system gets slow.
Please see attached. Any help would be much appreciated!
Saif
(3,346 Views)
Hi Vhha,
Ok, this makes for 125 Samples / 250 Samples/s = 0.5 s. Getting data for 0.5s sounds familiar, or?
Same calculation: 1000 / 250/s = 2s…
The x axis scaling of the graph has nothing to do with your DAQ part. And a graph only displays the data you provide it in your wire!
Solution: when you want to show more data in your graph you need to provide more data to the graph! Or in other words: collect the data in a buffer (aka array)!
(3,256 Views)
Thank you so much for your guidence
(3,211 Views)
