mnu file in create instrument driver project
I created an instrument driver using
Tools --> Instrumentation --> Create Instrument Driver Project.
The problem is that none of the new VI's appear in the instrument driver.
I tried adding the VIs as instructed on other posts by
Tools --> advanced --> edit pallette set
but it didn't work.
If necessary, I'll use VIPM but don't understand why the wizard isn't working.  Is the Create Instrument Driver Project feature still supported/ obsolete?
Seán
Message 1 of 10
(6,061 Views)
Which version of labview you are checking with?
-I tried with Labview 2015 and i can see the vis in Instr drivers.
-Are you creating driver from template or other option?
-Could you create sample project and post the screenshots so that it can help debug more.
uday
Message 2 of 10
(6,030 Views)
Hi Udka,
I'm using LabVIEw 2015 too and the driver was created from template.
As requested, I've attached some screenshots.  I can post the demo driver if that helps?
Seán
Message 3 of 10
(6,019 Views)
Are you sure you installed Labview and drivers properly in order? :https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8aNSAS&l=en-US
Here's more for troubleshooting : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI6tCAG&l=en-US
uday
Message 4 of 10
(6,013 Views)
LabVIEW was installed by clicking next.
My question ia about driver creation rather than preinstalled drivers.
Rgds,
Seán
Message 5 of 10
(5,988 Views)
Hi Sean,
Hopefully the below article will be useful for you?
https://www.ni.com/en/support/downloads/instrument-drivers/tools-resources/developing-labview-plug-a...
Nathan
Message 6 of 10
(5,971 Views)
NASmith,
Sadly not, I have looked at most resources including the one you linked and none of them seem to show how a VI can be added to an instrument driver.
This is why I'm wondering if it is obsolete or maybe there is something completely obvious that I have missed?
Rgds,
Seán
Message 7 of 10
(5,968 Views)
Here's a copy of the demo driver.
Question: How can I add a VI to the project so that it appears in LabVIEW 2015 under the driver when I right click?
Message 8 of 10
(5,961 Views)
Accepted by topic author SeanJ
Thanks for your suggestions.
I found the answer.  Navigate to the instrument driver you wish to update on the block diagram.
Now, Tools --> Advanced --> edit pallette
See screenshot below:
You can right click on the instrument folder to pick synchronize with directory and it's in.
Message 9 of 10
(5,958 Views)
Hi Sean,
I managed to add VIs into the Instument IO sub pallette by following the below guide:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGAyCAO&l=en-US
Please also see attached screen shot where I have added a test driver to the instrument i/o folder following the first link I sent you. I then created a vi called 'Test2.vi' and saved it in the action status virtual folder from the project. I then added this VI to the action status sub-pallete by following the information in the above link.
Hopefully this will give you the desired result.
Nathan
Message 10 of 10
(5,956 Views)
