mod(x,y) and Quotient & Remainder.vi yield different results
Is it normal that the mod(x,y) function doesn't yield the same results as the Quotient & Remainder.vi when x is negative?
For instance, if you use the Quotient & Remainder.vi with x=-3.7 and y=1, the results are:
x-y*floor(x/y)=0.3 and floor(x/y)=-4
which is consistent and also what I expected.
However, if you compute mod(x,y), the result is -0.7, whereas the floor(x/y) function yields -4, which is inconsistent.
Shouldn't mod(x,y) be equivalent to x-y*floor(x/y)?
Thanks if you can help.
(3,197 Views)
Seems like mod(x/y) has a bug when used with negative numbers. mod(-3.7/1) uses a floor of -3 instead of -4, so the remainder is -0.7 instead of 0.3. Don't use this, instead use the Q&R vi.
- tbob
Inventor of the WORM Global
(3,178 Views)
I am not aware of a "mod(x,y)" function in LabVIEW.
Could you tell us which mod(x,y) function you are comparing?
(3,178 Views)
It is the mod(x,y) when using formula node.
Apparently, it must not be used with negative numbers
(3,171 Views)
Well, since I wanted to use it in a formula node, I just typed x-y*floor(x/y) instead of mod(x,y). But I don't get why mod(x,y) is not simply defined like that.
Thanks anyway.
(3,163 Views)
