modal analysis
Hello, I am looking for some examples of soft to modal analysis.
The TDMS which I get from one modal hammer and one accelerometer I've got to load in program and do a modal analysis.
I want to see what this program should looks like.
I am totally newbie in LV.
Thank You
(3,717 Views)
Hi Jurij,
we got a couple of function VIs for modal analysis available for download here, I think these are the best starting point for your application. Check out the prewritten examples, try modifying some parameters, observe te code structure. There is also a whitepaper written on the subject, you can find it here.
If you have some other issues or questions, let me know.
Kind regards:
Andrew Valko
National Instruments Hungary
(3,637 Views)
Hi Andrew,
I tried to use the VIs that you linked, but when I'm using them I always get an error that some VIs couldn't be found.
The names of the VIs are:
si_chebychev matrix.vi
si_Estimate Model_input FRF format adjustment (SISO).vi
I use LabView 2015 Professional Development System and should have all required Toolkits. Are the VIs renamed in LV 2015 or something like that?
Kind regards
(3,287 Views)
