modbus and ethernet connection
i want a driver which help me to conect pc with RJ45  and which implements the Modbus protocol.
As modbus driver has inbuilt different VI s  Searial port reading(mainly Serial port init.vi which reads data from COM(RS232) port),,,, (for example in attachment that inbuilt VI s  r shown)so is  there any same kind of VI available which can read from RJ45 (An Ethernet conector)..and connect me to ethernet with labview ???
Your reply will help me implement Ethernet connection wiht Modbus in Labview,,,
Or if you have any alternet way to do the same,,  than your kind help will be appriciate
manisha
(2,654 Views)
(2,641 Views)
