modbus ethernet connection help
Hey, so I've been trying for a few days to connect to an Omega ir2c series with modbus over ethernet but I'm completely stumped.  A picture of my program is attached, as well as the error I get when I hit stop.  Currently when I hit run it looks like I just keep getting an error in "TCP Write in MB Ethernet Transmit".  I wasn't exactly sure on what parameters to use but currently my starting address is 39 because the address in the manual (below) is 27 and I converted it to decimal because it looks like that was hex.  I followed peoples suggestions in other threads and tried 39, 38, 40, 27, 26, and 28 with the same results.  The other thing I was not sure about is transaction id.  As best I can tell from other people on the interenet this is usually 1 but could this be my problem?  Also, I am able to log data in excel using a macro they supplied for iseries communication so I know the device is connected properly.  When I open a connection in MAX it says it successfully opened a visa session but there is a little warning exclamation point over the device for some reason.  I'm using ip address : 192.168.1.201 on port 1000.
Here is the communication manual for the device:  http://www.omega.com/Manuals/manualpdf/M4911.pdf
Normal manual in case:  http://www.omega.com/Manuals/manualpdf/M3752.pdf
Any help would be greatly appreciated.  Thanks in advance,
Alex
(3,569 Views)
update:  I think I have established communication now by opening up a web browser and typing in the ip address.  Then I had to change an option to enable modbus despite doing this on the device already.  Also, my port had to be 2000 instead of 1000 ( I think the provided software uses 1000 and blocks modbus from using it).  Now I'm getting modbus exception code 3 (which sadly I'm excited about because at least something is happening).  If anyone knows how to fix it I'd appreciate it.  Thanks
(3,562 Views)
yet another update:
It appears that changing the "Number of Connections" setting from 0 to 1 is what allows me to get the exception error 3.  If it's set to 0 then I get the Modbus write error from before.  Still have no idea how to get passed this exception error though.
(3,555 Views)
Hi Alex,
Have you looked through any of the documentation on our website for MODBUS communication over ethernet?  In paritcular, section 2 and 3 of Developer Zone: Introduction to MODBUS.  There is some good documentation on the setting up your MODBUS master, and using bound variables.  Addtionally, there is some discussion about how the I/O Server is involved with this process.
(3,514 Views)
