modbus ip shared variable network failure
I am using lab view 8.6 DSC module to communicate to a watlow system which contains five watlow 96 controllers and an EM gateway.  I have created shared variables for the process temperatures and setpoints for each of the five controllers using watlow modbus register Numbers with a 400001 offset.  I have also created shared variables for Updating,CommFail,UpdateNow,and UpdateRate which where predefined. I have error when starting the VI if the SV  has been  dragged and dropped into the block diagram. The message is  Error -1967353902 (The Modbus I/O server failed to receive any response from the Modbus slave device.) occurred at SV in vi. If I bind a variable in the VI to this same SV the error does not occur but the variable cycles between Good, Network Failure, No known value, and device failure as stated in the variable manager watched variables.  The Updating, CommFail and UpdateRate all have a consistent Good in the quality column of the variable manager.  UpdateNow has X in value, type, timestamp, and quality columns.  CommFail and Updating does cycle between true and false randomly.  I have tried a third party software called SpecView 32 demo to see if the commincation with the modbus system is not working and I can create five watlow controlers on my screen and direct them to the ip address along with a unit address and the system works without faults.  This leads me to believe the commincation bewteen the SV Engine and the IP address is not correct.  HELP Please.
Robert Jensen
UND EERC
Message 1 of 1
(2,965 Views)
