modbus mask
I have a question about MODBUS/TCP.
I have to write individual BITS to a holding register. Unfortunally, holding registers only accept unsigned values (numbers).
Therefore I need to convert my bit value (e.g. 101000 > 5).
But now I want to write a single bit value, without touching the other bit values. I think I need some kind of MASK for this to tell LabVIEW which individual bits I want to write.
Example in attachement.
Does anyone have any experience with a MASK in MODBUS/TCP in LabVIEW?
I have found on the internet things about "Holding Register Bit Mask Writes" and that Function Code 22 should be used, but I do not know how this can be used in LabVIEW.
Info about a mask in MODBUS (top of page 3)
http://www.micronor.com/products/files/AN112/AN112_NIModbusTutorial.pdf
How a mask should be used in writing a register (section 4.3.4 Mask write register (FC 22))
http://www.rtaautomation.com/modbustcp/
Arjen
(5,880 Views)
Accepted by topic author Arjennn
First read holding register then set your bit later write it. Its same only
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(5,867 Views)
Hello Ranjeet_Singh,
Thank you for your reply.
I have thought of that way of "fixing" it, but this solution will create extra (unnecesary) data traffic. It is not a nice solution.
There must be another way to do this ??
(5,866 Views)
Hello Arjennn,
Do you have the hardware available.
Have you already tried to work with the NI Modbus Library and taken a look at the examples?
Do you have the hardware available so that you can do some tests?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,819 Views)
