modbus pr300 yokogawa
Hi, I am using a communicazione modbus / TCP with PR300 yokogawa.
After some readings(3,5,6, the numbers is variable) from the d registers, the program gives me error (err 66 or err 62). Why?Regards
(3,949 Views)
(3,948 Views)
The error appears in TCP write in the figure ('immagine2')
(3,945 Views)
Are you using Windows NT?
See the follow document, is it your case?
http://digital.ni.com/public.nsf/allkb/76D7453569E80A09862566DA0056B30D?OpenDocument
D. Beninato
(3,916 Views)
hi, no I use windows xp...what do you do?Smiley Sad
(3,907 Views)
 ops...what can I do...?
(3,892 Views)
I have the error 62 when I increase the time between a reading and the other
(3,755 Views)
