modbus read multiple regs array size always 9
ok, here is what I want to read from modbus. Its 2 different controllers with different maps, but for the same machine. So I want to log certain values in SQL and also display them. Ideally I make 2 read vis, then arrange all the values, send another array to the PC. If that array to the PC is always the sameand I make 2 read vis, with different key options like the vi I posted earlier, this should work.
The key could be a .csv file, easier to edit.
Also, since its about 100 values, a tag would be nice.
Message 21 of 21
(586 Views)
