modbus
i am having a problem with the MODBUS Communication that is, I have a DSP which has been used for the control the Motors and DSP is acts as server and CPU acts as claint and my question is  the protocal which is running on hardware is  MODBUS and the hardware is CAN Tranciver . here i want to communicate with the DSP with out the help of the CPU directly by the communicating port of the  DSP board and i have A NI CAN tranciver, CAN Protocol with VI . Is it possible to communicate with same CAN tranciver to  DSP which is having diffrent Protocol if not How can have the talk between these two harwares
Or is it any possible to do with LabView to convert these Protocol using same NI CAN Hardware
Message 1 of 1
(2,665 Views)
