modbus
Dear Sir, Madam,
I have a machine TLM2 (engine control device) plugged by TCP/IP port. This device has the following modbus commands are supported by TLM2 .
Read Holding Registers (0x03) :
Read access on one ore more subsequent word registers.
Write Multiple Registers (0x10) :
Write access on one ore more subsequent word registers.
I would like to know how should I proceed to command this device using Labview.
Sebastien Champemaud
(3,359 Views)
You could start with the NI modbus library for a small amount of data.
If you want to access hundreds of registers, I would recommend the NI DSC module.
(3,341 Views)
Attached is a small vi using the MODBUS library.  It accesses a Serial MODBUS device.
Jason
(3,316 Views)
