modified affichage Ateasy to labview
bonjour
j'ai un affichage sur ATEasy est ce que je peux le transformer sur labview ?
si il ya .. c'est quoi la méthode ?
(1,085 Views)
Hi chedise,
@chedise19 wrote:
Good morning
I have a display on ATEasy can I transform it on labview?
if there is .. what is the method?
Are you talking about this ATEasy?
That would be a 3rd party test sequencer and I guess it would be a rather tough job to convert the whole test sequence to LabVIEW…
(1,078 Views)
What is it you try to do? ATEasy looks a lot like TestStand (but I doubt they support importing each others test sequences 😁)
Porting an ATEasy test sequence to LabVIEW is most likely an exercise in frustration. Reimplementing it in TestStand would be the more logical path but a lot of work.
Rolf Kalbermatter  My Blog
(1,074 Views)
