modified gamma function
Has anybody got any idea whether there are fitting vis that fit data to a modified gamma function?
(4,175 Views)
You might want to try the Nonlinear Curve Fit VI.   Do you have the expression for the modified gamma function?
(4,156 Views)
The equation is attached
(4,145 Views)
The easiest way is something like that:
 Andrey.
(4,133 Views)
Thank you for your help.
I have posted your code. What I need to do is to enter values for the constants in the gamma distribution to fit the shape of the data that is being plotted. In this example run the vi and read the attached txt file.The data will be plotted in 'raw data' plot. I need to define the constants to fit the raw data i.e. the plot in 'fit' should approximate the shape in 'raw data'.
(4,124 Views)
