modified waveform scalar limit comparison.vi
I did not like the resultant output waveform with the NAN values and broken graph lines. I modified the vi to clip the original signal at the limit input value (to have a continuous output waveform) or replace with 'NaN' values. I also added the options to invert the resultant and original waveforms independently.
(2,589 Views)
Neat fix. Why not submit the code to the example programs?
http://www.ni.com/devzone/dev_exchange/ex_search.htm
(2,589 Views)
