modify data logger(newbe)
I am using the solution wizzard to generate a data logger measuring voltage. I am trying to change the range on the Y axis so that it only goes to .05 Volts. Every time I try to edit the scale the program bounces the value back to 1V.
Any ideas?
Bernard
(2,889 Views)
Right click the Y scale and disable "Autoscale Y" from pop-up menu. This should be enough if the block diagram doesn't contain any property node to modify this value programmatically.
Hope this helps
(2,889 Views)
