modify the property of a DAQmx timing node
I have tryied to modify the property of a DAQmx timing node. I right clicked the property and choose "select property > brows>search> referecne clock..", after this, the new property didn't show in the list and I cannot select it. The list kept the same and nothing changed. What should I do?
Thanks.
(3,496 Views)
Hello Casperloo,
That is interesting I just attempted the same thing on my computer and the property node changed. Just to ensure I followed the same steps you took please take a look at the steps below and let me know if there is something I missed.
  1. You dropped down the DAQmx Timing Property Node
  2. You left clicked on the default property, and selected browse.
  3. You clicked on the search button at the top right.
  4. Then you entered in reference in the search bar.
  5. You selected one of the results in the search options and select OK at the center bottom.
Also, could you let me know what property you are trying to change so I can suggest an alternative method of finding this property?
Best Regards,
Izzy O.
www.ni.com/support
(3,466 Views)
Thank you so much for your reply.
I am doing the exact same thing as you did. After the final step (5th), the property list didn't update and nothing else changed.
I am trying to use a timing node to do sync of PXI 4496 with other PXI cards, I need to use PXI_CLk10 as the reference clock.
Yesterday I tried to open the class browser and find the Timing node with reference clock. But if I want to use two different properties, I still can't change one of them.
Thank you
(3,456 Views)
Hello Casperloo,
Your last statement makes me a liitle suspicious of what's going. So you cannot create a property node such as the ones below.
What about manually left clicking one of the properties and changing it like in the image below?
Also is this only occurring with the specific property you are trying to utilize or all Daqmx Timing properties?
Best Regards,
Izzy O.
www.ni.com/support
(3,437 Views)
No, I can't creat such a node.
When I left click it, it only shows:
                Browse
                sample quantity
                sample Timing type
No other things like your list. This happens for all the properties.
(3,426 Views)
I think its down to the device you have got. This link eventhough for a different error code may be helpful: http://digital.ni.com/public.nsf/allkb/05A563FE3AA7B3C286256FF90077C303
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,418 Views)
