modifying structure's color
I would like to know where is located the command or what is the method to modify a structure's colors.
THanks for your answers
Olivier
(2,605 Views)
Use the Set Color tool in the Tools palette. You might be careful to not over use this capablity or to carefully document what you change. If another programmer looks at your code later (even you may be that "other programmer" in six months), the non-standard colors may be quite confusing.
Lynn
(2,598 Views)
