modifying user input in for loop
Hi RavensFan,
Yes, I do know what auto-indexing is and I had noticed that had been the case when I connected it with VISA close outside the for loop (that's why I had kept it inside in the first place). Ijust realized I can change that tunnel to "Last Value" which worked - thanks!
Message 21 of 24
(1,287 Views)
A better practice is to use a shift register instead of last value on your references. If you for loop for some reason executes 0 times (i.e. auto-indexing and your array is empty) your reference will go bad on the output side of your for loop. A shift register keeps this from happening.
Message 22 of 24
(1,272 Views)
Hi Greg,
Would I need to initalize the shift register or anything?
Mridu
Message 23 of 24
(1,241 Views)
You initialize the shift register instead of having an input tunnel.
Message 24 of 24
(1,223 Views)
