module with digital and analog channel
Is there any module available with Digital and analog channels both. application is similar to NI 9401.
(2,848 Views)
Have you ever heard of the World Wide Web?  Google?  Bing?  A Search Engine?  Suggested search term, "NI Multifunction".  There are USB, cRIO, PXI, PCI, etc. "flavors".  You can also call NI ...
Bob Schor
(2,841 Views)
Accepted by topic author vivekkh
Hi vivekkh,
Yes.
NI9401 is a cDAQ/cRIO DIO module. It is not an "application"…
(2,836 Views)
Based on the example part given (9401) I'm tempted to guess that you're looking for a C-Series part, possibly for use with a cRIO or cDAQ system.
How many slots do you have available?
The multifunction stuff (ni.com/shop, then choose "Modules" under Compact RIO or "PC Based Systems" as appropriate) has not really overwhelmed me, and I'd guess if you want anything fast you might be better splitting your requirements to two modules.
Note that (at least for cRIO) some of the faster AI hardware is not under "Voltage Input" or similar, but "Digitizer".
GCentral
(2,832 Views)
It occurs to me as I read the post I just made, that there probably aren't many other uses for a C-Series part beyond cRIO or cDAQ... expensive paperweight?
GCentral
(2,828 Views)
Thank you sir.
by application i meant, where to use it.
i want it to simultaneous triggering of multiple experimental test setups.
best
vivek
(2,827 Views)
Sounds like you want digital outputs. Presumably the analog inputs are to measure something in the experiments?
I think some more information might lead to better suggestions.
GCentral
(2,824 Views)
