monitor size will be a problem?
Hi Mike
Well i want to use mouse_event function & also couple of other functions, like getwindowrect, keybd_event, etc..
Which LabView Input VI's are u suggesting mike?
Rajan
Thanks & Regards,
Rajan
Message 11 of 27
(1,763 Views)
Hi Mike
& what is this "depends"  Smiley Surprised
Rajan
Thanks & Regards,
Rajan
Message 12 of 27
(1,761 Views)
Hi Rajan,
there is an existing library for some of these functions. If you need more, you can use the "call library function node" to use the exported dll functions. Depends is a program with which you can read all exported function of a dll, but LabView do it as well. Smiley Happy
Mike
Message 13 of 27
(1,749 Views)
Hi Mike
labview can read functions of a dll. But how can we get the parameters of a particular function & there valid values.
For example, let us take the case of mouse_event function in user32.dll
http://msdn.microsoft.com/en-us/library/aa932376.aspx  << see this link of the documentation of this function.
Now one parameter specified in this function is "dwFlags"  .. now how do we know that what value to input to this parameter for generating an event like >> leftup, leftdown or rightup, etc
Rajan
Thanks & Regards,
Rajan
Message 14 of 27
(1,723 Views)
Dear rajan,
If you give 0 as input to dwFlags, it will select MOUSEEVENTF_ABSOLUTE  and
if you give 1 as input to dwFlags, it will select MOUSEEVENTF_MOVE
and so on.......
Hope it helps!
Message 15 of 27
(1,716 Views)
Dear mathan
well i also tought same way initially, but it doesntt work that way..
2 means leftdown
4 means leftup..
Thanks & Regards,
Rajan
Thanks & Regards,
Rajan
Message 16 of 27
(1,711 Views)
could you please post your vi or screenshot please
Mathan
Message 17 of 27
(1,708 Views)
Hi Mathan
I am attaching a example vi.
Rajan
Thanks & Regards,
Rajan
Message 18 of 27
(1,705 Views)
Hi Rajan,
you will find these information also in the internet. Here are the values for dwFlag for mouse event. It seems like they use one bit for every function. Smiley Wink
Hope it helps
Mike
Message Edited by MikeS81 on 07-28-2008 12:44 PM
Message 19 of 27
(1,697 Views)
Hey Mike
where did u find this .. can u please tell me the site name ....
Thanks & Regards,
Rajan
Thanks & Regards,
Rajan
Message 20 of 27
(1,688 Views)
