monitor standard out continously
I'm using Linux labview and need to continuously monitor another program output to "standard out" while it is running.  The System Exec.vi will only update the "standard out" when the program finishes.  Is there a direct way of doing this instead of redirect the standard out to a file then read that file periodically?
thanks,
Anh
Message 1 of 1
(2,493 Views)
