more help file access block and array
how could I save data using file access block or array then how could I read these data to using later.
is there any different way to save data without using file access or array?????????
(3,123 Views)
A good way to store data without using file access is the use of an action engine.
What kind of data do you have? Only if you have array data you would need to use an array. 😉
(3,110 Views)
actually I need to save the steerecord action blockring and the power of the servo motor,but I find different way ,its simpler and easier using record action block
(3,051 Views)
Sorry, I did not understand a single word of what you just wrote. 😮
  • What is "record action block"???
(3,046 Views)
