more options using dialog buttons
Hello!
In my application the user can save the results in a file. To input the name of this file i'm thinking to use a dialog button but i want that the user introduces the name of the file in the dialog button and then press ok. I'm looking for a dialog button where you can write  a name but i haven't found it. I want to know how i canbuild a dialog button where the user can write a name and the press ok or cancel.
If you can post a simple example it would be perfect.
Larson
Message 1 of 13
(3,855 Views)
Instead of Dialog button,  make a sub Vi pop up and you can type the path in it.
look at attached VI
regards
Dev
Message 2 of 13
(3,845 Views)
Hi
Without having seen the attachment of devchander, I just can say, why don't you use the built in file dialog?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 3 of 13
(3,842 Views)
hi Larson,
I've attached a VI for ur perusal.
Please let me know if this was what u were exactly looking for.
Partha.
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 13
(3,839 Views)
devchander and parthabe can you post this vi in labview 7.0 version.
Sorry, i forget put the version I'm using in my message.
Thanks!
Message 5 of 13
(3,835 Views)
hi Larson,
Partha.
Message 6 of 13
(3,833 Views)
hi I've attached for LV7.0
Regs,
Partha.
Message 7 of 13
(3,831 Views)
Hello becktho,
in this case i can't use file dialog because i'm using matlab script block to make some calculations and i need this name to open a .mat file.
But thanks fo your reply, I'll use in other part of my vi.
Larson
Message 8 of 13
(3,830 Views)
Hey larson,
here we go LabVIew 7 it will be.
And Thomas, Yes i had indeed used Dialog option for my sub VI's appearance.
Larson, find 2 Vi's.
 file dialog is the main vi and Pop is a sub VI
It should suit ur purpose just fine
regards
Dev
Message 9 of 13
(3,828 Views)
hello devchander,
i've seen your vi and is what i wanted. But i have a problem when you push ENTER FILE NAME, it starts running pop.vi and the machine works at 100%, how i can change this vi for not to carry the machine at full work.....with an event structure?? I don't know.
Thanks!
Larson
Message 10 of 13
(3,817 Views)
