motion assistant labview
hi
I have to control a motor speed using the PcI 7342 controller.
I have MID 7654/7652 servo motor drive and NI motion assistant.
MY hardware connections are proper.
I am using motion assistant to generate a arc move and then generating labview code .
I have inserted just a knob in the front panel to control the speed and made a slight modification in the block diagram to insert the knob in the place of velocity.
Now i am not able to stop the motor .
Can anyone help me to insert a stop button in the labview diagram.
Should i use configure inhibit output flex or just use the stop button in flex motion.?
i have attached the labview diagram....
Pls help me.
thanking you
sumitha ravindran
(2,892 Views)
Hello Sumitha,
The code generated by Motion Assistant is designed to run the arc move once and stop at the end of the move. The Arc Move step of the LabVIEW diagram is setup to wait until the move completes before stopping. There should be no need to add a stop button (or the Stop Motion VI) if the motor is configured properly. If this is the case, you should see the VI hanging in the Arc Move step. Is this what you see? Can you perform a straight line (point-to-point) move?
I noticed that you have another similar discussion forum post here. You most likely will need to solve the motor configuration issue first (which may also solve this issue).
Best Regards,
Jesse D.
Applications Engineering
(2,878 Views)
