motion detection
Hi...I am currently working on a project which requires me to detect baby abuse such as slapping or beating using the Kinect Xbox 360. I have already installed both SDK and the Kinesthesia on my computer, but i'm not sure how do i program it to detect the abuse. I am still new to the whole labview thing, hence can anyone provide me with examples asap please...Thanks
Message 1 of 9
(4,167 Views)
how are you detecting slapping or beating? by movement or sound....
  • once you can sense that, compare it to nominal level and bool out true
Message 2 of 9
(4,156 Views)
i am detecting it by movement ...May i have an example please...thanks
Message 3 of 9
(4,151 Views)
First work out which movement(s) relate to abuse.
Then track movements.
If the tracked movements are the same as the abuse movements then you have abuse.
Message 4 of 9
(4,131 Views)
how do i track the movements? Can i have example on that?
Message 5 of 9
(4,119 Views)
For tracking. you could for instance, get multiple joint positions over time.
I don't have a kinect so I can't help you with specifics of how to do it with the kinect,
Message 6 of 9
(4,104 Views)
should it be something like this?
Message 7 of 9
(4,096 Views)
That depends what ypu want to do. What are you trying to achieve with that VI?
Message 8 of 9
(4,026 Views)
http://forums.ni.com/t5/LabVIEW/abuse-Kinect-detection/m-p/2466742
Maybe u can take a look at my code which is attached at the forum there...I'm not sure if i did it correctly
Message 9 of 9
(4,015 Views)
