motor energy usage
This question may be very simple, but I am new to labview, so please bear with me. The attached VI is a very simple example of what I want to do, with numeric controls to represent how the incoming data can vary.
I am using a VFD analog voltage output to display the VFD power in labview (in kW). I want labview to be able to sum this data over a period of time and ultimately tell me the total kWH used. So basically if I were to graph the analog output, I would be interested in the area under the curve. It seems to me that the time domain math functions will do what I want, but I'm having problems controlling the rate that it sums. For example, in the attached VI I have a 1 second time delay. Ideally this VI on it's own would work fine for what I want. However this VI needs to go into a much larger VI, and the 1 second delay as built here, will slow the larger loop to iterating once every second which is too slow. How do I get it to just capture the data once every second, and sum it without delaying the loop speed?
Thanks!
(2,258 Views)
Accepted by topic author RPK2K5
Is this example answer to your question.
I change "delay.vi" to "wait for a multiple ofn millisecond".
loop normally execute in one second
(2,245 Views)
