move annotation label
I wrote an VI with a xy-graph in which annotation can be placed. All works fine when I run my VI but after I created an executable, I couldn't move the annotation label after I created an annotation. Has anyone an idea?
(3,337 Views)
Hi Festus
I've found the same problem, I was hoping someone would give you a solution. Have you reported it as a possible bug?
Ian
(3,315 Views)
Hi Ian,
I talked to a NI engineer and it semms to be a bug. He told me that the problem will be solved in the next version
Festus
(3,300 Views)
This has been reported to R&D (CAR# 3VD2I2IZ) for further investigation. A possible workaround is to move the entire annotation rather than just the label. Thanks for the feedback!
Jarrod S.
(3,278 Views)
