movement On dani
DaNI has encoders, which I believe are used for some PID control on the velocity setpoints.  If you look at the velocity setpoint control for DaNI, you will be able to see the encoder data, which then gives you position, which you can use to specify a distance for the robot to travel.
Message 11 of 30
(1,650 Views)
Thank you Karl, yes DaNI has encoders and we know perfectly how those encoders work. The thing is that we want to do something like the following:
     open the communication with DaNI
     open the communication with the FPGA
     initialize the encoders ( make the count equal to zero)
  1)   read the encoders
     if the count is less than a constant go to point 1; if not stop the DaNI.
That is all.
PS/ Is it the block diagramm a right way to think (in terms of the labView software)?
Thank you.
manolo
Message 12 of 30
(1,650 Views)
That sounds about right.  Does that code not work?  Can you post the code you have?
Message 13 of 30
(1,650 Views)
I will do it Karl. Let me see if I can connect to the robot.
Thank you and sorry for the late response. I was in class.
manolo
Message 14 of 30
(1,650 Views)
please, how can I attach a file here?
Thank you.
manolo
Message 15 of 30
(1,650 Views)
Reply and use advanced editor.
Message 16 of 30
(1,650 Views)
Thank you
Message 17 of 30
(1,650 Views)
I need to go to class,,later on I will send the code.
Thank you
Message 18 of 30
(1,650 Views)
Alternatively, just take a screenshot.
Message 19 of 30
(1,650 Views)
Good morning Karl, here it is.
The arrow is broken. Why?
Thank you.
manolo
Message 20 of 30
(1,650 Views)
