moving average filter
Explain why you divide by the mean?
Message 11 of 19
(1,927 Views)
You simply can't know what the mean is going to be of 10 points...if you havn't received those points yet.  You can wait  until you get 10 points and only calculate your values after that.
Message 12 of 19
(1,920 Views)
its part of the processing, some sort of normalizing the data.
Message 13 of 19
(1,917 Views)
yes of course, but my gold standard is as if i had the 10 points already, that is the value I am comparing my results to.
Message 14 of 19
(1,915 Views)
Well, you need to simply wait until you have 10 point before dividing by the mean and then wait again. If you already have the final array, simply loop to get all sequential subsets and process each. Here's a quick example.
(What is your LabVIEW version? For older versions, the code needs to be changed a little bit. EDIT: changed to 2012)
Message 15 of 19
(1,906 Views)
I have 2012 version.
The purpose is to not wait for all the points(which is actually much larger, in the range of thousands).
I am receiving these blcoks of points(10) in real time from a device,and i want to process them.
however the result of processing the samller blocks of data should be similar to as if i had the whole file (for example 8000 points),.
I have attached an image of an example output graph.
The blue plot is the ideal plot.(using all the points from  a file)
The green plot is using slightly fewer points,
and the red plot is using much less points (which is closer to the number of points i will be using.)
as you can see the red plot and blue plot are different. The shape is similar however the values are quite different.
Message 16 of 19
(1,901 Views)
I don't see how dividing by the subset mean can convert one of your curves into another.
Message 17 of 19
(1,894 Views)
well there is a high pass filter and a log after this stage, the results are the final result after all the processing.
but i was thinking that it is the division by mean that is causing the variation.
Message 18 of 19
(1,886 Views)
I have to admit that I am quite lost as to what the goal of this exercise is.  😞
Bill
CLD
(Mid-Level minion.)
Message 19 of 19
(1,865 Views)
