moving channels to other modules?
is there a simple way of moving channels to differnt modules on the c-rio im currently having to check instances on every channel and then moving them to a differnt module is there a simple way that would alllow me to move a channel and it update every instance on my code?
(2,532 Views)
Hi cbt,
Can you give me a little more information about what you are trying to do here?  Are you using the cRIO in Scan Mode or FPGA Mode?
Jayme W.
(2,499 Views)
