mpc in fpga
sir,
myself sajingopi doing masters in automation. I am trying to implement Model predictive control in fpga and the platform that i am using is labview. First stage of the project was over in which i tried to implement MPC in labview and got the required response. But when I tried to implement that one in Labview -fpga module i came across with some errors. Later only I understand that lot of blocks that I used in labview can't be used in Labview-fpga.
Heard that  I should implement mathematically the complete algorithm of model predictive control in labview-FPGA module even for simulation. So will you suggest me how should I approach to this problem.?
Message 1 of 1
(2,840 Views)
