ms word tables borders and shading
I'm using the "word tables borders and shading.vi" and trying to put a border around the first row including between columns and the "inside line style" active x function in the word_set_table_borders.vi is being ignored. The file is attached. Open the library and run the word table.vi. You will have to create test.doc on the root directory on the hard drive. Any suggestions?
(2,822 Views)
I ran your code and it worked fine. The top row of the table had a darker rectangle around it. I did have problems opening the file and it crashed my LV at first. I suspect there may be a corruption in the binary executable of the VI. Try pressing control-shift-run arrow on your top level VI to force LabVIEW to rebuild the binary executable of the VI.
(2,822 Views)
The code will build a darker rectangle around the top row, but did the top row have 2 darker vertical lines seperating the 3 columns? For some reason the code to build these 2 vertical lines is being ignored. I've run the program on both 2002 and XP systems.
(2,822 Views)
