mt ldpc encoder error
I want to use mt ldpc encoder function.However, whenever I add that function, VI does not work even though I do not add anything. When I keep clicking on the erroneous function, I see PHI and Inverse E VI is broken. And inside that, adding function does not work properly. Why is that so? Thank you so much
(2,747 Views)
Hi kenehekene,
It's difficult to say what the issue might be without seeing your code. Could you post your VI or a screenshot?
(2,712 Views)
