multi analog inputs and single analog output implemented in PCI 6221
hi, everyone
In my application, i want to ouput analog voltage and reviceid two analog input synchronously (but need not simultaneously for two input). I post a waveform diagram to explain my need. as shown in illustrations , the AO will update at each raise edage of period, but AI 1 only sample at each t2n period and AI 2sample at each T2n+1 period. Is is possible to implement this in PCI 6221 ? or I must buy a Simultaneous Sampling card ?
If it is possible, can anyone give me a example to implement this? because I do not find similar example in example lib
Thanks in advanced
Message 1 of 1
(2,407 Views)
