multi channel with different ranges?
If I wanna to define two channales in one task and define diffrent specification for each how I should do that?
for example I wanna to use A0 0&1 but want to limit the min/max value for the Ao1
Ela
(3,273 Views)
Interestingly, this might have been answered today in thread 'Specifying
input limits for multi-channel DAQ' by D. Kuntson. Use a separate DAQmx
Create Channel function for each channel but use the same task. You can use
the DAQ Assistant and 'Generate Code -> Configuration' to see how it's done.
"elahetal" <x@no.email> wrote in message
news:1268691007486-1091341@exchange.ni.com...
> Hi, If I wanna to define two channales in one task and define diffrent
> specification for each how I should do that?for example I wanna to use A0
> 0&amp;1 but want to limit the min/max value for the Ao1 Thanks,Ela
(3,260 Views)
It helps when you post a link to that thread rather than just the name.  Specifying input limits for multi-channel DAQ
(3,249 Views)
It also helps when my name is spelled right.Smiley Wink
(3,244 Views)
