multi column list box
Hi all,
I am in need of your help right now...
In my application I used one multi column list box.
It looks like below...
Tests         Status (Ready / In progress / Completed)
T1               Completed
T2               Ready
T3               In progress
T4               Ready
One separate VI will run the selected tests in the multi column list box.
Test status is maintaining in the test result array (2D array), it looks like
0        T1                        T3
0       Completed            In progress
What I want to do is, search the T1 & T3 in the multi column list box and update the test status (Completed / In progress)
Request your help on this.
Ram
using Labview 8.5 / GOOP 3.0.
(2,961 Views)
You can use the Item Names property node read/write new values into to list box.
Use the replace array subset vi to modify the output array from the Item Names, then feed it back in.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,955 Views)
Similar to this...
(2,953 Views)
