multi commands UDP write
Hi, How can I write multi commands in a single UDP write? I tried ; and & but didn't work. Thanks sbz
(3,029 Views)
Hi sbz,
Writing multiple commands to a single UDP Write Function would just require placing the VI inside a loop structure.  You can find some helpful examples in the NI Example Finder (in LabVIEW, navigate to Help » Find Examples... » Browse » Networking » TCP & UDP).  I hope this helps!
(2,995 Views)
