multi data files arithmetic media
Hello. So..i have 120 data text files with 2 columns. i want to make from 5 to 5 files, arithmetic media for columns, i mean lets say file names are 1.txt(columns A1, B1) , 2.txt (A2, B2), 3.txt, ... 10.txt, ...120.txt. As result i have to create for 5 to 5 files, one file that should have the arithmetic media for (A1+A2+A3+A4+A5)/5 ans second column (B1+B2+B3+B4+B5)/5. But i want to do this for 120 files, so from 120 files should result 24 files with 5 to 5 files artihmatic media. How could i do this automathically? just chosse the directory with files, cause it-s hard to select first 5 files, the second 5 files, etc.
the columns names are an example, columns don-t have names, they-re simply with numeric data, example:
6.1384 0.0000
6.1357 0.0000
6.3582 0.0000
6.1585 0.0000
5.9201 0.0000
6.2191 0.0000
Thanks...
(2,674 Views)
Hey florin.unga,
I'm not sure what you're trying to do in this application. Could you clarify a bit? Here is an example that shows you how to read data from a file in LabVIEW, that should be a good start on how to retrieve the numbers from the files, then you would just need to perform your calculations. Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(2,656 Views)
