multi duty in generation frecuency
Hello everyone
I hope you are well and can help me with this problem that has arisen.
I have a phonic wheel or sprocket from a car
which has different valleys
I need to know how I can replicate this signal with their respective% duty of each pulse
attached the type of pulses found in the phonic wheel
I am also working with an NI6218
Thanks a lot
(948 Views)
Hi osvaldo,
Build a waveform from your signal data and output the waveform using your DAQ device…
What have you tried so far?
(909 Views)
