multi lines overlay
hi all,
i am trying to create multi lines overlay for .VI which is created to find lines in an image using shape detection. how can i overlay all the lines, detected by shape detection? can someone help?
awng nu.
(3,783 Views)
Hi awng,
do you use the Vision Toolkit? What have you done til now?
Mike
(3,767 Views)
hi mike,
i use vision assistant 8.0. Until now i just only can do one overlay line.
awng nu.
(3,745 Views)
First I would like to inform you of the Machine Vision board. You are much more likely to receive an answer on that board.
But my first suggestion is to look at the IMAQ Overlay examples on our website. Find out which one does what you want to do or close to what you would like to do. Then adapt the code to your particular application. Once you have done this, if you are still having trouble overlaying a line I recommend posting on the Machine Vision board more specifically what you have done and what you would like to do that you could not figure out yet.
Vince M
(3,713 Views)
hi seVEMes
sorry for the late reply. thank you so much for your advice. now, i can create multi overlay lines as i want.
aung nu
(3,674 Views)
