multi plot in chart
Hello All Engineers,
I have attached a VI with this post.
Here in this VI i have two systems data coming from the field, getting the single value from each system in every second. I want as a result 2 waveform in the output chart but i am getting only single waveform here as a result. Suggest me the modifications in VI.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,971 Views)
Accepted by topic author Himanshu_Goyal
Hi Himanshu,
have you ever looked at the context help, when the mouse is over the terminal of the chart? It clearly says which datatypes result in several plots in the chart: you have to wire a "D array or a cluster.
So simply replace your BuildArray by a Bundle node!
(2,968 Views)
Thanks GredW for quick response.
Smiley HappySmiley LOL
Thanks and Regards
(2,965 Views)
