multi plot wave form chart
i am acquiring 16 channels simultaniously scan rate of 1000samples/second.  using chart with single channel (array of data format) i can see 10 sec duration. with multiplot view of least 4 channel i used waveform property but this will not getting 10 sec duration of x. this is showing just like a graph.
how to show my multiplot at least channel in one chart with continous updation....?
Balaji DP
Message 1 of 11
(5,583 Views)
I did not get your question. Can you explain your question using screen shots?..
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 11
(5,578 Views)
please find an attachment.
i am trying to show the 4 channels of with 1000samples/second. even i am using the chart. i can see only 1 secon of data.
if i try with single channel array of data with out using wave form property with  chart i can see 5 minutes of updattion.
how to see multiple plot atleast 4 channel with 5 minutes of duration?
Balaji DP
Message 3 of 11
(5,575 Views)
Hi Balaji,
I tried to plot two plots with waveform property. I did not face such problem.
I had not connected "t0" input though.
Gaurav k
CLD Certified !!!!!
Message 4 of 11
(5,564 Views)
Try without connecting "t0". Place chart on front panel again.
Gaurav k
CLD Certified !!!!!
Message 5 of 11
(5,559 Views)
i tried without connecting "t0" with chart control... but it act as a Graph not a chart (recorderd), its updates 1000 samples every second... i want to show a history of last 10 seconds samples of data
if i connect with the single input array of data with out using build wave form then i getting history of data.
Balaji DP
Message 6 of 11
(5,550 Views)
Hi Balaji,
I tried other way. Just have a look. Bundle 1 point of each array (Channel) and then give output of for loop to waveform chart.
Let me know if it helps.
Gaurav k
CLD Certified !!!!!
Message 7 of 11
(5,545 Views)
no, please check this attachment.
my inputs are 2 dimension array of channels,
row1 - > channel 1 (1000 samples)
row2-> channel 2 (1000 samples)
Balaji DP
Message 8 of 11
(5,537 Views)
is there any posibilities?
Balaji DP
Message 9 of 11
(5,518 Views)
Is this What you want?
Gaurav k
CLD Certified !!!!!
Message 10 of 11
(5,494 Views)
