multi spread sheet files, continuously.
I am figuring out how to read the multi spreadsheet files continuously,
i tried bundled them and add them together but it dint came out as i expected.
the progrram i attched is fully working but only for 1 file.
anyidea how to make it to read many spreadsheet files and show as weekly, or monthly data analysis
Message 1 of 11
(4,203 Views)
Hi mintonemin,
use a loop to read more than one file.
It would also help not to use a file constant for the filename...
Message 2 of 11
(4,189 Views)
I have been out town, didnt really get how to do with while loop.
can show me example?
Message 3 of 11
(4,161 Views)
anyone!? 😞
Message 4 of 11
(4,131 Views)
Use "Read from Spreadsheet File" inside a loop. Concatenate the "all rows" output. When done you'll have all the rows from all the files concatenated into a 2D array. I'll leave you to figure how to feed the file names to the loop.
Message 5 of 11
(4,124 Views)
I dun get the meaning of how to concentrate the file.
can show me the example?
Message 6 of 11
(4,093 Views)
Try the attached vi.
Message 7 of 11
(4,088 Views)
We keep getting file is not a resource file.
i attached 4 example file .
Message 8 of 11
(4,080 Views)
What is the file format you are using? If you are using .csv file format use *.csv in the pattern (Sorry I haven't included * in that) then you will get only the required files.
Message 9 of 11
(4,075 Views)
we did that too.
it still show the same error.
Message 10 of 11
(4,072 Views)
