multi-state graphic in labview 8.2
Is there a good way to make a multi-state indicator on my front panel VI using Labview 8.2 with DSC.  For example using Lookout you can create a multistate object a picture, indicator, and so on.  If one boolean value is true then one picture is shown, if that one is false and another is true you can show a different picture, and if both are false then you would have yet another picture.  I can not come up with a good way to do this in labview?
(4,367 Views)
There's always the picture control, which let's you do anything imaginable in the UI, but it might require a bit of coding.
Have a look at the LV Picture Control thread for some ideas.
(4,361 Views)
There is some flexebility in labview and you can get indicators presented in couple of way other than default labview led indicator.
Here is the link of the blog Multi State Indicators . There is picture explaining three ways to get more vivid indicator. Have fun..
(2,899 Views)
