multichannel simulated inputs
Is there a tool in labview (or a simple way) to create a multichannel simulated input in labview? To clarify, I want to create a wavefrm with X number of channels and was looking for a good way to do it. Thanks.
Intern NSWCCD Carderock.
(2,838 Views)
If you have NI hardware already installed, with the Measurement & Automation Explorer, NI-DAQ 7.4 now gives us the ability to simulate the installation of many of NI's DAQ boards, including a limited simultation of what signals they might return. Otherwise, buiding a waveform and then fanning it out to multiple channels with the addition of offsets and noise on a per channel basis shouldn't be too hard.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,832 Views)
a very very simply way to simulate X Channels for a WaveChart
is to use two for Loops look at my vi.(LV 7.1)
(2,817 Views)
